TEK WIKI CONTACT CONTAMINATION/CLEANING Contacts require cleaning: (1) when visual inspection shows contamination on the contacts or pads; (2) after solder work has been done on the ECB [flux fumes may leave a thin film deposit on contact surfaces] (3) after board wash, which cantrap _ contaminants around closed contacts. Two cleaning procedures are recommended. Procedure A is preferred. Use procedure B only if A proves inadequate. WARNING: Do not use No-Noise or other contact lubricants on cam switches. They are designed to operate dry, and lubricants tend to trap dust particles. Cleaning procedure A 1. Remove the cam cover. 2. Clean contact pads and fingers with isopropanol (isopropyl! alcohol) or fotocol (ethyl alcohol) using a soft brush and alcohol on cotton swabs. Be very gentle around the contact fingers. Rotate the switch shaft during cleaning and drying to prevent dissolved contaminants from collecting around closed contacts. 3. Allow switch to air dry for 60 seconds. 4. Blow out remaining residue with an air hose while rotating the shaft to prevent trapping of particles. 5. If contacts are clean, proceed with checking for contact pressure and damage. If contamination persists and cannot be removed with this procedure, use procedure B. Cleaning procedure B — Removing hard films This procedure is to be used only on films not removeable by procedure A. CAUTION: There is only about 0.0001 inch of gold on the contact pad surface. Any abrasive material will remove some of this gold, thus increasing risk of corrosion and decreasing the life of the switch. 1. Rotate the switch shaft to open contacts to be cleaned. 2. Cut an Eberhard Faber ‘Pink Pearl’ eraser into the shape of a screwdriver tip small enough so that it can be inserted between the contact fingers and pad. Note: do not use typewriter- or fiberglass-type erasers because they are too abrasive. 3. Use light strokes to remove contamination. Use only enough pressure and strokes to change the gold pads to a more satiny, yellow finish. 4. Follow up with the alcohol cleaning procedure A to remove residue. COMPONENT LUBRICATION KIT 003-0342-01 CONTENTS 1 ea - NO NOISE, Pressurized can, 006-0442-00 1 ea - WD-40, Pressurized can, 006-0172-00 1 ea - G.E. VERSILUBE G305M, Silicon grease, 006-1353-0@ Of *1 ea - Detent lubricant, container-applicator, 006-0219-00 12 ea - Detent balls, replacement, 5/32 in. diameter, 214-0493-00 12 ea - Detent balls, replacement, 3/16 in. diameter, 214-0494-00 12 ea - Detent balls, replacement, 7/32 in. diameter, 214-0593-00 12 ea - Detent, roller, replacement, 0.125 in. OD, 214-1127-00 1 ea - Brush #1, 003-0016-00 1 ea - Instruction booklet, 070-0496-01 *The container applicator stem is sealed for shipment. Remove red tip cap, and cut off about 1/8 inch of stem end
Если Agats из Европы, тогда его лживое заявление : вполне объяснимо, так и надо делать. И вам бы следовало у него поучиться, как надо относиться к чужим, а как к своим.
Очень сложный проект Вы делаете, искренне радуюсь его реализации. У меня всё очень просто, - навесной монтаж. OTL - это Супер !
Алексей1, на форуме люди не только из РФ, а со многих стран мира, при ответах это уместно учитывать. Если человек общается на русском, это не говорит, что он из ближайшего села... Жуковский, кстати, в их числе. Так что общаясь с иностранцем Ваша реплика звучит малость нелепо.... Наш портал международный и многонациональный.
В общем решил сделать два макета, один канал SRPP от Станислава а второй Броски...послушаю это стерео и в железо пойдет вариант с лучшими для меня звуковыми характеристиками. Станиславу и всем участникам обсуждения спасибо!, надеюсь это тоже будет история со счастливым концом...
Это и для меня вопрос открытый... Так как на макете длительной эксплуатации не было... Но за время макетирования режимы стояли как вкопанные... Будем надеяться что все будет работать долго и надежно... Для меня это также как и для вас всех проект опытный и первый в жизни OTL...
Надо отвыкать от привычки целовать боты иностранцам. Всё, что делается сейчас, делается впервые и, как обычно, у нас. Запад может только украсть.
Перепаять не долго...часто придеться подстраивать?
Подстроечные резисторы зря запаяли со стороны деталей... Я выше писал , что их нужно запаивать со стороны ламп, чтоб в готовом устройстве регулировку производить не разбирая корпус... В верхней части корпуса предусмотрел отверстия на каждый потенциометр, маленькие аккуратные отверстия для тонкой отверточки... Посмотрите на моей плате как нужно поставить потенциометры и точно соблюсти расположение регулировочного винтика... Вот эти отверстия
По мере поступления комплектующих, сборка идет к завершению. Еще на 2 комплекта, сразу набираю детали. Следующий будет на 6с33с
Total Posts111.7k
