отправка за счет покупателя почтой России от 400р
дополн. информация по запросу (фото) в лс
The Sylvers – Something Special (1976) Capitol Records 1EX 2VGVG+/EX 250
Club Nouveau - Listen To The Message (1988) Warner Bros. Records EX+/NM- EX+ shrink /cut 490
Club Nouveau - Life, Love & Pain (1986) Warner Bros. NM-/NM- cut/shrink 550
DeBarge - Rhythm Of The Night (1985) Gordy NM-/NM-EX+ 450
General Kane - In Full Chill (1986)Gordy  NM M/NM shrink 900
Ready For The World - Long Time Coming (1986) MCA Records NM-/NM- shrink 490
The Deele - Eyes Of A Stranger (1987) Solar NM/NM- shrink 590
The Four Tops - Tonight! (1981) Casablanca NM-EX+/EX+ 790
Willie Hutch - The Mark Of The Beast (1974) Motown NM-/EX сзади наклейка 2100
The Isley Brothers - Smooth Sailin' (1987) Warner Bros. Records NM/NM- shrink 690
Commodores - United (Мелодия) NM-/EX- 200
Boyz II Men - Cooleyhighharmony EX/EX+ 250
Jackson Family – Jackson Family (1990) Command Records NM-/EX+ 750
The Winans - Return 1992 (Russian Disc) NM-/EX+ 490
Sly & Robbie – Rhythm Killers 1987 (Island Records) EX+/EX+ 699
Take 6 - So Much 2 Say (Russian Disc) NM-/EX 500
Eddy Grant – At His Best (1985) Poland EX+/EX+ 490
Philip Bailey - Family Affair (1989) UK Nm-/EX+ 550
Rick James – Glow (1985) US EX/VG++ 450
The Temptations - Surface Thrills (1983) Germany NM-/EX+ 900
Ready For The World – Ruff 'N' Ready EX+NM-/NM- cut shrink
Cherrelle – High Priority (1985) DEmo NM-/NM- 1900
Paradise Express (1979 Fantasy) EX+/EX+
Diana Ross – Baby It's Me 1979 (Мелодия) exex-/ex 170
Dionne Warwick – Friends (1985) Мелодия NM-/EX-210
Patrice Rushen – Pizzazz (1979) Elektra EX++/EX+ 2400
Nicole – What About Me? (1985) Portrait EX+/NM- 550
Branjo Sound – I Wanna Dance Bump (1978) VG+/EX- 150
Ashford & Simpson – Solid (1985) Capitol Records EX+/NM-650
Janice Marie Johnson - One Taste Of Honey (1983) Capitol Records NM-EX++/EX cut 1250
    • Токи: Т13, Т14: 3 мА Т10, Т11: 3 мА Т9, Т12: 6 мА Т3, Т4: 600 мкА Т1, Т2: 70 мкА. Для получения высокой линейности на 20 Гц и выше ёмкость С2, С3 должна быть 100 мкФ. Можно ставить оксидные конденсаторы без особых требований к аудиофильности, с большими последовательным сопротивлением ESR и последовательной индуктивностью ESL. Модель повторителя при 2 В ампл сигнала 20 Гц на сопротивлении нагрузки 33 кОм, ёмкость С2, С3 - 100 мкФ + 1 Ом + 100 наногенри (типично - ESR=20...30 миллиом и ESL=30 наногенри) показывает Кг 0,000.04%.
    • На счёт Нейро - от души...спасибо. У нас на старом сайте был один товарищ, который всех убеждал, что у него трек Цоя мп3 звучит намного лучше разных оцифровок , магнитоальбомов и сд группы Кино. В качестве доказательства рассылал нам всем в лс ссылку на скачивание этого мп3...... - Послушайте, сами убедитесь. Но у того мнение было хотя бы в единственном числе, ну что поделаешь, так он воспринимал музыку.
    • Неинвертирующий усилитель при усилении сигнала от источников с высоким выходным сопротивлением, например, РГ, вносит большие, но не замечаемые конструктором искажения. Это происходит за счёт взаимодействия нелинейного делителя, состоящего из линейного выходного сопротивления источника и нелинейного входного сопротивления усилителя. Нелинейным оно становится вследствие 1. изменений напряжения между коллектором и базой или затвором и стоком, что приводит и к изменениям в такт с сигналом входящих в делитель паразитных параметров транзистора: модуляции толщины базы напряжением на коллекторе, что выражается в зависимости тока коллектора от напряжения на коллекторе 2. Нелинейной зависимости Скб от напряжения Uкб, или Ссз от напряжения Усз, например: Получается вот такая эквивалентная схема нелинейного делителя для входа неинвертирующего обычного усилителя: С таким фокусом пришлось столкнуться в усилителях "Амфитон-104": узел РГ -> Т1 и "Амфитон 002-с": см. узел РГ -> Т2. Этот эффект также есть во всех усилителях в точках перехода с РГ на следующий каскад усилителя. Подметил этот эффект Никитин, но с его решением можно не соглашаться, если предложить своё.   Искажения - суть плоды ИЗМЕНЕНИЙ РЕЖИМОВ активных элементов усилителя в течение периода сигнала. Устраняем ИЗМЕНЕНИЯ РЕЖИМОВ - получаем линейность. Без ООС.  Режим это напряжение между выходными электродами элемента, напряжение меж его входными электродами и его ток. Способы устранения изменений режимов: 1. Для ООСного усилителя достаточно устранения изменений режимов единственного неподООСного каскада - каскада сравнения. Для этого нужен набор максимального усиления холостого хода Кухх, охват ООСью и правильная коррекция. Тогда Удифф (режим входного каскада по напряжению меж входами) стремится к нулю в силу приобретённого Кухх: Удифф = Увых / Кухх 2. Для безООСного повторителя устранение изменений режимов достигнуто а) слежением по входному напряжению, что даёт неизменность выходных межэлектродных напряжений, Укэ, и б) высокими импедансами нагрузок всех каскадов, до выходного - это даёт исключение изменений токовых режимов транзисторов, но полной неизменности режимов ВСЕХ каскадов в усилителе достигнуть невозможно, поэтому в) для уменьшения последствий изменений межэлектродных выходных напряжений выходного каскада действует уже низкое выходное сопротивление предыдущего каскада, г) токовые изменения режимов выходного каскада уже компенсировать нечем, да и незачем, учитывая назначение повторителя - работу на высокоомное входное сопротивление УМ. Но можно выходной каскад зашиклаить, это повысит линейность повторителя на низкоомных нагрузках. Если мы знаем причину искажения, можем решить проблему искажений РГ-усилиель проблему двумя способами: или неправильно, или эффективно. Или мы, не считаясь с затратами, создаём релейный регулятор громкости с процессорным управлением - что уменьшает искажения, но не устраняет их полностью, или схемотехническим решением удаляем первопричину искажений - изменение напряжения коллектор-база в течение периода сигнала. Второй способ сводится к линеаризации входных каскадов следящей обратной связью по напряжению на коллекторе/стоке. Это значительно упрощает и удешевляет узел РГ-повторитель и придаёт ему высокую линейность.   Мы можем вживить такой повторитель: или лучший, симметричный: в имеющийся усилитель и не заботиться о сопротивлении регулятора громкости. Тем более, в "Радиотехнике УП-001" этот резистор дискретный, и разбирать-пересчитывать-перепаивать его на меньше сопротивление не хотелось ну никак. Буфер был построен и измерен: Для 2 В на 33 кОма нагрузки. Неплохо для штуки, появившейся из сплетения аксонно-нейронных узлов и кремниевых массивов процессорного арифметико-логического устройства.
    • Еак копирует сд треки  не лучше проводника виндовз. А может и хуже. Многие отмечали кто сравнивал по звуку
    • Если в усилителе есть лампы, то компенсатор не поможет. А в транзисторном - туда же, куда заводится ООС.
    • Михаил, я например, раньше на выходе ставил тамуру а-4714 с прямонакальными триодами 45 и 2А3, а про входные выше писал о вэб каледе, это рфт, трансляционные усилители, и о кинапе, это всё микрофонные трансформаторы, подходят при перекоммутации для некоторых наших целей, типа для головки Денон 103, на вход усилителя вероятно тоже.
    • Изначально макетил на 5ю4.739.001. Полоса ужас!
    • Спасибо.  А куда заводить схему конпенсатора, если усилитель без ОУ, или вообще гибридный к примеру?  И схему можно реальную с номиналами?
    • Вот такие. Обозначений на борту нет никаких.  Идея была в усилителе на работу. С подключением к выходу телефона. Мощности в 1 ватт достаточно.  Трансики по НЧ без проблем. На частоте 21кГц (0дб), но после резкий спад. На 25кГц уже - 3дб.
    • В место светодиодов можно ставить стабилитроны на 15в и там в схеме установка нуля подстрочникомR10.
    • Эту схему собирал, работала и звук вроде по тем временам неплохой был, вроде там были проблемы с балансировкой постоянки на выходе поэтому продолжать не стал
    • Мне показалось, речь о трансформаторах от КИП. Помнится, раньше довольно активно использовались трансформаторы от Усилителей Электронных. Пермаллоевые, в круглом стакане. Хотя, насколько помню, Ктр у них большой. Речь про какие-то другие.
    • Тему почистил, за дальнейший офтоп буду наказывать. Надоело.
    • А мне кажется, есть смысл в первую очередь уточнить, с каким источником это работало. Допускаю, что мощный операционник на выходе СиДи такой трансик без проблем прокачает, у него динамическое десятки-сотни ом, а вот какой-нибудь винтажный фишеровский корректор с есс83 на выходе - сдуется, независимо от сечения, витков и количества никеля в трансе. Однако если усилитель работает от преда с хорошим понижающим трансом на выходе, задача выглядит вполне решаемой, хотя мне повышение как-то не греет (исключения - МС и Дак, там это в жилу). Просто мотаемые мною повышающие трансы почти всегда показывают различные сияющие грани рукожопости, в отличие 1:1 и понижающих, которые, бывает, очень даже получаются. И если вдруг речь о трансике КИНАП, то, если не путаю, похожим коэффициентом обладали повышающие трансики с фотодатчика оптической дорожки. С низкоомным источником они достаточно широкополосны.
      112.6k
