Open Club · 6 members
Open Club · 29 members
Территория чатем.
Open Club · 17 members
Вокруг джаза
Open Club · 44 members
Open Club · 54 members
Soberi.pro
Open Club · 18 members
Смонтировал оба канала.Платы на резиновых амортизаторах,по шумам и прочим грюкам всё нормально. СЮТ ,спасибо .
Jshop.cc, CC, CVV, Ransomware As a Service, loading bank accounts and credit cards, browser stealer, RAT, Payload, Botnet, Keylogger, The New Genesis.Market Marketplace 2024, non-VBV CC stores, list of Cardable Gateway 2D sites, virus, malware, Trojans. OTP/2FA bypass tool, Office 365 corporate logs, payroll, BEC, professional email compromise account shops, bank log sites, hacking and spamming account shops, brute force, cracking, tutorials, methods, guide, valid and legitimate onion sites, online banking and shop services, shell, fullz CC, bank open ups, deposit, pickups, magbo cc invitation code and cracking. You can also request for a particular country's CC/CVV shop you are looking for, and I will get it for you. Dumps with pin, real physical ID cards for UK, Canada, USA, and Australia to be delivered to your house, and fullz info are also available. I'm also a carder and spammer too, and you can also spread my ransomware file online and social media to earn good money from. An Example: - https://imgur.com/a/dCDjxAw Screenshots: https://imgur.com/a/Pe5ZiMz https://imgur.com/a/fey5Fhi https://imgur.com/a/ZmCUewK https://imgur.com/a/FwIGVU7 https://imgur.com/a/KJ4jwr0 https://imgur.com/a/PSAiZbo https://imgur.com/a/hka4f6W https://imgur.com/a/juyk14S https://imgur.com/a/IwWldcW Video: https://www.mediafire.com/file/jzfvs1kn3o2pv49/Screen_Recording_20241011_205250_Chrome2.mp4/file Dark Web Site: http://pasteboxx44wtzbm3ldjkcncls6uggi7mipmdwef5zza6wjqrqrtxdid.onion/paste.php?id=127879 http://zerobinftagjpeeebbvyzjcqyjpmjvynj5qlexwyxe7l3vqejxnqv5qd.onion/?a0dcfac33c7f0957#z0lEWtohF0BncadNi+k28r1XSSvJK+6CwxlY7L59tQk= You can contact me for more proof if you want. Escrow is also accepted. You can also contact me for this on Telegram. Telegram ID: https://t.me/hXckerman Telegram Group: https://t.me/invitationcodess Signal Chat: +13474601414 WhatsApp Chat: https://wa.me/3474601414 Element Messenger: @foster911:matrix.org Session Messenger ID: 0524511a1cfc16bc2b6e28a6bf24bf1f453539c173d5b3810d3cc4e92da82a8834 TOX: 1D7E7FF7720A580C291CFA76BA028F597888C1D9F85650E358168B5ACB7AA65DB7671EFDA8AB
"Те инженеры", наверняка бы, весьма удивились бы, весьма мягко говоря, НЕцелевому использованию малоподходящих ламп, при наличии ими же разработанных других таких, но подходящих.
Каскад на 6г1 прекрасно работает и на 50 ком, и на 22, и даже на 10к. Например, прямо сейчас у меня работает, на РГ 33 ком. С питанием не 410,а всего каких то 280 вольт...
Простите, уточняю для остальных. На транзисторах BSP129 собран буфер без обратной связи и эти транзисторы не требуют никакого смещения входного сигнала. Применение этих уникальных транзисторов предложил К. Мусатов, по его измерениям искажения около 1% при амплитуде 4В (почитайте его статью про усилитель для наушников). Здесь, конечно, уровень ожидается не более 2В. И буфер здесь - это вынужденная мера, ну какое выходное сопротивление каскада на 6Г1? Высокое. На входной регулятор громкости, даже 50ком, в усилителе этот каскад 6Г1 работать не сможет.
By Colonel Burrous · Posted
Я частенько слушаю Ронни, особенно когда требуется взбодриться-забойный, академический рок-н-ролл, с мощной гитарной и духовой ритм-секцией. Ронни Доусон-мало кому известный певец, гитарист, барабанщик, музыкант местечкового значения, остававшийся в тени таких звёзд, как Джин Винцент, к примеру и другими, но тем не менее-талант, техника, хорошее владение инструментами-это всё слышно на записи. Увы, нет Ронни уже среди нас...рак горла. -
Даёте гарантию?
By johnson1496 · Posted
Я так понимаю, что SRPP на сдвоенном триоде в одном баллоне чтобы оба триода деградировали одновременно и одинаково не наш метод? Потому что слишком просто? -
Да, я записывал с помощью Audacity в файл 24/192, потом изучал его в SpectraPLUS-SC, подключив упомянутый файл коррекции. Но можно записывать и с помощью SpectraPLUS-SC. Увы, все WAV-файлы уже стёрты, - они были ОГРОМНОГО размера.
450TH считай тоже, что и ГМИ-30, только внутренее скорее всего больше за счет усиления. Вообще за океаном похоже не сильно заморачивались с серией этих ламп. Одна и та же система, чуть больше - чуть меньше, или одна, две, четыре.....
Восстановил JBL D208 диффузора мелкого не было , решил штампануть середину более глубокого диффузора наружу на диаметре 70мм
По 304 TL замечание мимо, мю=12 - хорошо годится как УНЧ. Это пара - 304ТН генератор ВЧ, 304TL модулятор. Но чинил как то крутофирменный аппарат на похожей на них 450ТН(!!!) от того же изготовителя, что 304. 304 же TL работают хорошо, но недолго, ибо рассыпаются катоды. И при пересылке рассыпаются тоже... ГМ-100, насколько помню, лампа для трансляционных усилителей, РР в классе В, качества звука от них не требуется. 811 - опять же чисто генераторная лампа. Для генераторов с самовозбуждением . Кстати, рекламка 304-х нашлась
Кстати говоря 833 ( или наоборот) это аналоги , там даже если присмотреться аноды отличаются. Эти ньюансы могут и сработать для нашего применения. Но главное это то что я например не слышал и не видел двухтакта на этих лампах . Это может сработать как например с 6п3с - однотакт на ней , бред , а в двухтакте нормально работает. Но вот помещение для прослушивания однозначно должно быть большим.
Описание-то никак? Не все смогут уследить полет чужой мысли... Получается, что у вас буфер на BSP129, который со встроенным каналом. Для этого достаточно ограничить напряжение на затворе оного ограничителем по вкусу. Относительно "нуля". На стабилитроне в диодном мостике, например, из BAV199, например. Или двух стабилитронов и одного сдвоенного bav199, например. Или хуже того, +/-15 В, каковые уже имеются и одного сдвоенного bav199. Потому как пару десятков миллиампер такое сооружение выдержит. Почему, если вы поставили твердотельный буфер, не поставить твердотельный серво, на ОУ? С исполнительным твердотельным же полевым n-канальным транзистором? Вместо пентода в триоде.
Total Topics8.9k
Total Posts98.3k
