Правильные усилители
Recently Browsing 1 member
Open Club · 59 members
БАЛАНС
Read Only Club · 1 member
так еще раз, я и написал что не писали с лент, а писали ленту на цифру и после и делали ремастеринг. У мелодии ничего не написанно не расписанно, не знаю надо ли описывать, но как примерпишут так - The intial recordings for this album were made by using a vintage valve-based 1/4" 2-track Studer C37 tape recorder, which is considered to be the legend of the Studer professional studio recorder line. It was first released in 1960, and for the next 10 years remained as the main protagonist of many of the most famous album recordings of all time. The Studer C37 used in this recording came from the legendary Riga Recording Studio, where the Soviet era label Melodiya (Мелодия) made recordings from the 1960s to the 1970s, and has been fully restored and carefully maintained by Mārtiņš Saulespurēns. This album was recorded live direct to analog tape without any editing or overdubbing. или так дурят у нас голову : This Kristaps Vanadzinsh Trio recording is a testament to the vitality and sophistication of the jazz music tradion. It pulses with the history of jazz music – melodic ballads and harmonically rich jazz miniatures which, within the paradigm of acoustic jazz, offer both peaceful harbours, and the excitement of the journey. Album recorded on the special analogue recording session at concert hall "Latvija" in Ventspils, Latvia. Performed, mixed and recorded live direct to analog tape using a Studer A 80 1/4” two-track tape recorder without any editing or overdubbing. Kristaps Vanadzinsh - piano (Steinway) Jānis Rubiks - upright bass Rūdolfs Dankfelds - drums, percussion All music composed by Kristaps Vanadzinsh. Except “The Land Of Hope And Glory” composed by Edward Elgar and “After The Rain” composed by John Coltrane. Recorded on August 11. - 13. 2020 at Concert Hall “Latvija” Ventspils, Latvia. Recording Engineer: Mārtiņš Krastiņš. Assistant Recording Engineers: Mārtiņš Saulespurēns, Krišjānis Geidāns. Tapes prepared for vinyl release by Mārtiņš Krastiņš. Digital Mastering at HELI media. Mastering Engineer: Mārtiņš Krastiņš. Piano tuned by Jānis Kalniņš. Produced by Mareks Ameriks. Front Cover Photo: unknown. Sleeve Design: Edgars Ameriks. и не поймешь, то ли аналог, то ли цифра...в начале вроде лента и с нее, позже появляется цифра...или я не правильно перевел?
я видел магнитный тонарм наоборот, снизу нить, сверху магнит...очень опасно, но кто то делал. А здесь что два магнита шарика на траверсе а сверху снизу магниты цилиндры? НЕ видно регулировок никаких магнитного потока и т.е демпфирования
Я читаю, что написано у Мелодии дословно: Домысливать и додумывать зачем?. МАТРИЦЫ с ОРИГИНАЛА, а не матрицы с ремастера цифрового или аналогового. А дальше самое интересное, смотрим обратную сторону конверта.
Бред. Не может хорошо звучать усилитель с микросхемой на входе. Она убъёт и задушит всё. Суховский высокой верности -тому пример. -
ну просто супер кайф!!!!! Завидую белой завистью. А слева траверсы вниз это крепление арма, здоровая латунная головка? а что это такое? вверх увнизу магниты без нити? что это за чудо юдо? В Osiris MkII используется оригинальная магнитная подвеска в одноопорной конструкции, которая также включает магнитный антискейтинг и позволяет легко регулировать угол вертикального слежения на ходу. Противовес легко вращается для точной настройки вертикальной силы слежения и легко фиксируется на месте с помощью установочного винта
из Красноармейска. Он же СМЕРШ-ДДТ-Sagittarius- и т. п. на разных форумах.
Пара выходничков для SE ГИ-3. 15к/8ом. Имено на них макетировался проект описАнный на форуме. Железо ШЛМ21*32. Первичка 60гн/500ом постоянному току/30ма. 8000р/пара. Могу залить компаундом в колпаки (+2000р).
https://newaudioportal.com/topic/16540-усилители/#comment-181832 -
Из Барнаула человек. Остальные от Виктора Жуковского из Донецка. -
Владимир, а это чей разроботки усилитель? И выше представленные Вами Спасибо
Могу с автором связать. Не могу без разрешения барыжить чужими усилителями.
Total Topics10.1k
Total Posts111k
