Продам комплект радиоламп для постройки малогабаритного высококачественного однотактного усилителя на 2-2.5 ватта , чего вполне достаточно для комфортного прослушивания музыки ,но а если понадобится мясо , то это отыграет сабвуфер . В интернете можно найти с десяток проверенных рабочих схем , по вкусу .
Tungsram 80 + Siemens 81 + Telefunken el95 - 5 т.р. за комплект .
https://shemaforum.ru/malenkiy-lampovyy-usilitel-se-diy/?ysclid=mjkvk7qgfj140607781
    • На этом  (6Ф6С)   А на 6ф3п - я ничего не трогала. По поводу использования вторичной обмотки в роли катодной - есть в мыслях отдельный проект, с триодом
    • We need to look at the constant current effect of a tube heater. Let's give a realistic, numerical example for the well known 300B by Western Electric. The heater voltage is 5V, at 1.2 Ampere. They never specified a tolerance for either of those values. What is sure, they write this is a voltage specified tube. This means, best lifetime you occur at 5V, not more and not less. There is a strong tendency by users, to take 10% tolerance for anything without tolerance specification. However this is not so. Each 0.1V you deviate, in either direction, will reduce the lifetime significantly. (The military handbook says: exponential to the power 13). So if you are 2% off, the tube will not reduce lifetime by 2% but >20%. Most likely +/- 5% is the (deadly) limit. So be nice to the tube, and give it exactly 5V, it is the best you can do. Make very good note, that a few percent is very much. Now, what current will it draw at 5V? Well, most of the time 1.2 Ampere, but not always. Add to this the natural tolerance. But...how much is that? If you ask the so called 'experts', a 300B is supposed to draw 1.2 Ampere, period! So they want zero tolerance on the current draw. Then, If you ask the experts about the voltage, they tell you 10%. This 'expert' expectation is a very crude error. It is based on no data sheet, no literature, and not in line with anything will observe with real, physical tubes. Even so, if there is tolerance on the 300B heater specs, it is in current draw, and not on the voltage. In real life, most WE 300B at 5V will draw from 1.2 Ampere, but some will draw 1.1 or even 1.3 Ampere as well.
    • Всё, разобрался, спасибо, есть что порассматривать, бессчётное количество, жаль, что только на телефоне могу смотреть, всё мелкое! Я про такие магнитофончики в детстве читал в журнале радио, в отделе За рубежом, на целый разворот схемы были опубликованы с минимумом транзисторов, восхищался изобретательностью их! Чудо какое, переменная скорость выходит у него, подмагничивания нет, не понятно, что с ним, мелко, с одного плеча унч сигнал снимается при записи, постоянка подаётся(?), стирать как, слева от головки постоянный магнит? Речь записывать, репортёрский точно! Наоборот, очень интересно и как раз на фоне сурового, если т.с. не возражает.
    • Этот сделан в штампованном стальном корпусе с миллиметр толщиной.Скорее как репортёрский ,даже микрофончик есть в комплекте. А вообще любили они игрушки делать. Просто на фоне серьёзных аппаратов как то не ловко выкладывать. Вот ещё из небольшой коллекции.Привод даже без тонвала
    • Вот здесь можно ознакомиться с самой разной экзотической техникой. https://p12.su/Sony_BM-17_Dictator.html?ysclid=mli0yqij3i557597848
    • Можно по конкретнее . Вопросы к членам форума , для понимания . Один режим -5ц3с  обеспечивает рабочий ток 180 ма   и второй режим -  40 ма .  При каком режиме больше (меньше)  будет срок службы? У одного кенотрона 5ц3с накал 4,8в (поверие в кругах ..., что так звук лучше), у второго такого же - 5 в .  Какой прослужит дольше ; рабочий ток одинаковый. Вопрос из области -  ""  и так дажэ бывает ...""  .    Китайские  моноблоки Лайн магнетик -  китайцы назначают ( официально , т.е. в расчёте и практически ) накал лампам 300В при их рабочем токе в драйверном каскаде 50ма , напряжение накала -  4,1 в (при калибровки питающего сетевого ).    Какую долговечность они заложили ?  В + или в  - ?  .   По даташит , как известно , для 300В опускать накал ниже 4,7 в не рекомендовано .
    • У меня такая плата... На стадии нмлпдеи, без корпуса фона не было ... Тишина...
    • Спасибо! Я просто оговорился, думаешь одно, а рука пишет другое, катушечки же на фото. Главное мотор, а схемка немудрящая совсем, у меня скопилось некоторое количество транзисторов из 60-х, если что. Да, даже я, старьёвщик, такой древности не видел в реале!
    • Точнее у бобинника. Моторчик с центробежным регулятором. К сожалению полазили в схеме шаловливые ручки.Сломали этот самый регулятор и что то коротнули в схеме.Моторчик восстановил,а вот дальше ещё предстоит.Заботливые японцы схему приклеили на крышку.
    • Никогда не видел такой привод у маховика тонвала, судя по серой эльне он японский, и у него весь тракт на пяти транзисторах? Эта весна может быть интересна, если в ней стоит импортный лентопротяг, или хотя бы мотор японский, у нас в городе делали такую штуку, под названием ритм, завод часовой-ракетно-электроприборный находился в трёх шагах от моего дома, и большая часть соседей работала на нём. Оригинальный механизм, два маховика, вращающиеся в разные стороны. В противном случае, если там всё советское, то проку никакого, и есть вероятность занести в квартиру тараканов, от которых избавиться ещё та проблема!
    • Пробовал и в SE и в РР, режимы разумеется подстраивал, включал в триоде, ул, пентоде, не так давно вовсе макетил РР с КО, во всех случаях, кроме КО драйверами были 6Н1П (нэвз) и 6Н2П с титанированными анодами, EL84 пробовал, с подстройкой режима зашли теслы, телампы и поламы не очень понравились, до EL86 руки не добрались, акустика была Coral-DX5 и dynaudio emit m20 P.s. больше всего по звуку на мой ух понравилось пентодное включение 6П14П-ЕВ с КО (17), о драйверной лампе в этом тандеме уже был пост
    • Это полная абстракция в ответе..... Пробовал в какой схеме - хотя бы однотактной или двухтактной....с какими лампами драйверами. На каком усилителе промышленном, само собранном..... с какой акустикой и в каком музыкальном жанре тестировали........  Не пошли 6п14п/6п43п, а какие пошли? И почему снова тогда эту тему поднимаете - почему снова к ним возвращаетесь в обсуждении? А пробовали их иностранные аналоги El84/EL86? Сделал более 20 усилителей на 6п14п/6п43п/El84/EL86..... Чуть меньше сделал на EL36(6п31с) и на близких к ним лампам 6п13с и близких иностранных аналогах.... И получал ОЧЕНЬ разный звук в зависимости от схемы и  СОБСТВЕННОЙ квалификации и опыта. Так то выходных ламп не очень много ...... основных типов применяемых ламп в звуковых целях - пару десятков семейств(базовая лампа и аналоги).... Наиболее массовых в применении половина из них..... или даже треть..... Так что разговор нужен предметный - в каком применении конкретно понравилась/не понравилась лампа.
    • Подвал Pioneer CT-3 (она же CT-F2121 для Европы) : Настройки оставил заводские, только индикаторы слегка подправил, они были настроены для долби-уровня, который на не нужен. Хорошо дека пишет, и воспроизводит тоже! Завёл переговоры о покупке оной...
      10.1k
      110.6k
